- 16 aug 2011
- 80
- 1
- 0
Ik heb een set condensators over om een ecu te kunnen voorzien van een set nieuwe,
Ik heb vorig jaar 2 sets besteld om de verzendkosten te kunnen delen.
Wat heb je hier aan vraag je je af?
Your ECU capacitors are strongly suspected if you have at least one of the following intermittent issues on your Lexus or Toyota:
● problems in getting into diagnostic mode or scanner says "no communication"
● random dropping into "limp home" mode
● weird shifting problems
● OBD port is unresponsive, seems dead
● throwing random fault codes
● engine won't rev out/rev limits at 2000 or less rpm
● engine runs like crap, then suddenly runs fine again
● random not starting or cutting out
● low idle or erratic idle
● often very hard to start, requires starting fluid
● transmission will not automatically shift, only manual shift is possible
● transmission jerks from 1st to 2nd gear, and kinda slips from 2nd to 3rd
● no A/C compressor operation
● idle speed rolling up and down, or sometimes too low and sometimes too high
● speedometer not working reliably
● speed (cruise) control not working
● tachometer not working sometimes
● air bag light flickering intermittently
● A/C going into reset with flashing front defog light (front defog light typically flashing 10 times)
● check engine light on sometimes, but no codes stored, often in concert with ECT light
● ECU not communicating with scanners or not displaying codes with jumper installed
● bad sulfur exhaust smell in concert with not running right above
Montage handleiding en meer info:
http://www.clublexus.com/forums/ls4...exus-issues-solved-ecu-leaking-capacitor.html
Met andere woorden, niet verkeerd om gewoon preventief te doen.
Prijs: 25 euro incl verzendkosten.
