- 28 aug 2008
- 66
- 0
- 0
Zojuist vond ik dit op het internet: Een "hack" om de irritante gordel-waarschuwing uit te schakelen.
Het zou hier alleen gaan om het alarm, niet om de weergave op het dashboard en het middenconsole.
Of het ook werkt op de Europese modellen weet ik (nog) niet, maar in Down Under schijnt het in elk geval wel te werken op modellen vanaf 2007.
TESTED ON: 2007 IS250 Sports with enhancement pack
SUCCESFUL/FAIL: Success
LEVEL OF DIFFICULTY: medium (would be helpful if you had a third arm!)
INTRODUCTION
It is possible to disable the warning chime that sounds whenever the driver or front-seat passenger unbuckles their seatbelt while the car is in motion. I find this annoying when entering the private estate where I live, as I have to unbuckle my belt for a long reverse into my driveway/garage.
STEPS
1. Press the START button twice (without foot brake) to power up the system
2. Press the trip reset button couple of times until the ODO is displayed (not trip A or B)
3. Turn off the system again by pressing START again
4. Unbuckle the driver's seatbelt
5. Turn on the system again (press the START button twice without foot brake)
6. When the dash lights come on, press and hold the trip reset button for about 10-15 seconds (possibly longer if it doesn't work first time)
7. While still holding the trip reset button, buckle the driver's side seatbelt
8. The odometer display should read "b ON" or "b OFF" (toggle this with the trip reset button)
9. Process should be completed when you unbuckle or turn the system off
The setting is retained until changed again (by simply repeating the process).
INTRODUCTION
STEPS
