GS wielmaten
Erick
13 jun 2010
863
20
GS wheels fitment:
The stock GS 17" wheels, as far as I know, are 17x8 with 235/45/17. I have owned two sets of aftermarket wheels for the car, 19" Volk Racing AV3 19x8.5 +38 front and 19x9.5 +38 rear, and now I have the 20" HRE 540R 20x8.5 +32 front and 20x10 +43 rear. I would classify my 19" setup as a conservative setup as it doesn't flush totally with the fender but have zero rubbing issue, whereas with the HRE, the setup is very aggressive and is flush perfect with the fender, but has slightly rubbing which was fixed relatively easy.
The following are the wheel sizes that I would suggest for the GS (if you don't want to have a staggered setup, just put whatever for the front in the back). When I say the setup is conservative, it means you don't have to do any fender modification. When I say aggressive, that means you probably have to do the rolling or shaving. And in the case of professional, then some major suspension changes would have to be made in order to fit the wheel, and should be left to professionals hence I won't go over how here.
18" Difficulty
18x8 +32 18x9 +32 conservative
18x8.5 +38 18x9.5 +38 conservative
18x8.5 +38 18x10 +44 conservative
18x8.5 +32 18x10 +42 aggressive
18x9 +38 18x10 +42 aggressive
18x9 +35 18x10 +35 professional
19" Difficulty
19x8 +32 19x9 +32 conservative
19x8.5 +38 19x9.5 +38 conservative
19x8.5 +38 19x10 +44 conservative
19x8.5 +32 19x10 +42 aggressive
19x9 +38 19x10 +42 aggressive
19x9 +35 19x10 +35 professional
20" Difficulty
20x8.5 +38 20x9.5 +38 conservative
20x8.5 +38 20x10 +44 conservative
20x8.5 +32 20x10 +42 aggressive
20x9 +38 20x10 +42 aggressive
20x9 +35 20x10 +35 professional
** on 20" wheels for the GS, keep in mind that the wheels are out of spec so the overall diameter is off by about 6%. Your speedometer would be off, meaning that when the speedometer says 80mph, you are actually going at around 85mph already. Plus, because of the 1" larger diameter overall compared to 18" or 19" (with tires), you have to be careful with your lowering. From my experience, if you lower your car to 2 fingers, provided that you have the correct offset, you shouldn't rub (or very slightly) the top of the wheel well. If you go 1? finger gap or less, when going over uneven road or dips, you will most likely rub the top part of the wheel well. Over time you will see part of the rubber wheel well flap got rubbed away. Moreover, with 20", you will rub when you put your steering wheel at full lock (either left or right) and mostly when backing up. This is due to the bigger diameter and when you turn, you rub the front and back of the wheel well (this is one reason why 20" are the biggest rims you can put on the GS with reasonable widths).
When it comes to tires for the GS, the following setup are preferred:
Wheel Size Tires Within Spec?
18x8 235/40/18 245/40/18 yes
18x8.5 245/40/18 yes
18x9 245/40/18 255/40/18 yes
18x9.5 275/35/18 yes
18x10 275/35/18 285/35/18 yes
19x8 235/35/19 245/35/19 yes
19x8.5 245/35/19 yes
19x9 245/35/19 255/35/19 yes
19x9.5 275/35/19 yes
19x810 275/30/19 285/30/19 yes
19x8 235/40/19 245/40/19 no (fat setup)
19x8.5 245/40/19 no (fat setup)
19x9 245/40/19 255/40/19 no (fat setup)
19x9.5 275/35/19 no (fat setup)
19x10 275/35/19 285/35/19 no (fat setup)
20x8.5 245/35/20 no
20x9 245/35/20 255/35/20 no
20x9.5 275/30/20 no
20x10 275/30/20 285/30/20 no
Keep in mind different brands of tires, even with the same profile, will be different too. So for very marginal setup (read: aggressive), the tires might provide the 1 or 2mm that makes all the difference. Tires like the Bridgestone SO3 and Dunlop P9000 are very rounded and "meaty". The rounded corners will help to avoid rubbing. On the other hand, from my experience, Nitto, Pirelli, Yokohama, etc... tires are very "square" so they might enhance the rubbing factor.
Re: Wheel Fitment.
heeft iemand dit verhaal ook gewoon in het nederlands? ben maar en simpele slachter. bvd raymond
Re: Wheel Fitment.
Misschien helpt het volgende een beetje.
Het eerste lijstje bestaat uit moeilijkheidsgraden per velgmaat. Erachter een kreet als:
- conservative = behoudend = je hoeft de randen v/d wielkasten niet uit te rollen, dus geen aanpassingen.
- aggressive = aggressief = grote kans op uitrollen wielkasten, dus aanpassingen.
- professional = professioneel = aanpassingen aan vering etc. en wielkast om e.e.a. te laten passen.
Tweede lijstje is de voorkeur bandenmaat, welke (yes) binnen gewenste specificatie vallen en niet aanlopen of schuren tegen wielkasten etc.
Hoe meer werk (professioneel), des te beter het uiteindelijk oogt. Je kunt je wellicht voorstellen dat zulke aanpassingen soms het aankoopbedrag van de auto overtreffen... ;)
Re: Wheel Fitment.
jij weet nog al veel over autos! wat ben ik nou ong kwijt voor leuke velgen? niet te gek natuurlijk. en welk soort velgen liefst 19 inch staan nou echt mooi onder de gs :rulez:
Re: Wheel Fitment.
Welnee, ik ben slechts vertaler :D
Hier staan (beetje onderaan) wat aanbieders van o.a. velgen: viewforum.php?f=17
Je kunt het best eerst goed ori?nteren, aangezien velgen nogal smaakgebonden zijn. Vaak kun je bij de website van zo'n leverancier intoetsen wat voor type auto je hebt en je krijgt dan een overzicht van velgen die geschikt zijn, evenals prijzen.
Hou er rekening mee dat je er met enkel velgen niet bent, er moet ook een (duur) bandje omheen... Hoe groter de velgmaat, hoe prijziger dit vaak wordt. Dit heeft met name ook te maken met de kwaliteit der materialen, vormgeving, etc.
Pas op voor al te goedkope velgen. Deze lopen meer kans te 'vervormen', aangezien er bij 18 en 19 inch minder bandwang over is om schokken op te vangen.
Grote velgen zonder verlaging van je dempers/veren is uitermate lelijk (krijg je een soort terreinwageneffect)... Dus dan kijk je vaak ook nog naar een verlagings(schroef)set.
Re: Wheel Fitment.
Je kan best een mooie setje wielen vinden voor 1200,-. Het is alleen een kwestie van zoeken en kijken wat je mooi vind en wat bij de auto past. Velgen is een kwestie van smaak en daar kan soms een stevig prijskaartje aanhangen.
