Kwam deze op google tegen...
REMOVAL
1. REMOVE STEERING WHEEL PAD
NOTICE:
If the airbag connectoris disconnected with the ignition
switch at ON or ACC, DTCs will be recorded.
(a) Place the front wheels facing straight ahead.
(b) Remove the 2 steering wheel lower No. 2 covers.
(c) Using a torxsocket wrench, loosen the 2 torxscrews.
HINT:
Loosen the 2 screws until the groove along the screw circumference
catches on the screw case.
(d) Pull out the wheel padfrom the steering wheel and disconnect
the airbag connector.
CAUTION:
When storing the wheel pad, keep the upper surface
of the pad facing upward.
Never disassemble the wheel pad.
NOTICE:
When removing the wheel pad, take care not to pull the airbag
wire harness.
2. REMOVE STEERING WHEEL
(a) Disconnect the connector.
(b) Remove the steering wheel set nut.
(c) Place matchmarks on the steering wheel and main shaft
assembly.
(d) Using SST, remove the wheel.
SST 09950–50013 (09951–05010, 09952–05010,
09953–05020, 09954–05021)
