- 26 feb 2014
- 79
- 7
- 8
Wie o wie is er in het bezit van software waarmee je settings kunt wijzigen? Volgens mij is een van de apps aristo ofzo? Dit zou dan moeten werken via OBD
Intressant vraagje wat kun je wijzigen ? Ik doe al 8 jaar autos uitlezen.
Doors / Windows / Remote
Wireless door locking
Enabled / Disabled
Blink turn signals when locking/unlocking with remote
Yes / No
Beep when locking/unlocking with remote
Yes / No
Volume of beep when locking/unlocking with remote
Off / 1 / 2 / 3 / 4 / 5 / 6 / Max
Beep when opening/closing windows with remote
Yes / No
Warn (beep) when door can't be locked because it's still open
Yes / No
Ding when key is left in the car
Enabled / Disabled
Ding when key is out of the car and ignition is on
Yes / No
Warn (beep) when a window is still open when locking doors
Yes / No
Warn (beep) when sunroof is still open when locking doors
Yes / No
Panic function on remote
Enabled / Disabled
Open trunk lid with remote
Single click / Double click / Long press / Very long press / Disabled
Re-lock doors automatically if you unlock, but don't open a door
Yes / No
Re-lock doors automatically if you unlock, but don't open a door within?
30 seconds / 60 seconds / 120 seconds
Unlock doors via remote
Driver's door on 1st press, all on 2nd / All doors on 1st press
Unlock doors via physical key
Unlock doors via smart key (door handle button)
Max number of consecutive lock/unlock cycles via touch sensor
Unlimited / 2 times
Auto-lock doors when moving
On / Off
Lock doors when shifting into gear
On / Off
Unlock doors when shifting into park (P)
On / Off
Unlock all doors when driver's door is opened
On / Off
After locking with smart key, don't allow re-opening within?
0.5 seconds / 1.5 seconds / 2.5 seconds / 5 seconds
Smart key location to start car
Front seats / Anywhere in vehicle
Unlock trunk when smart key in range
Yes / No
Open windows and sunroof by turning and holding key in door lock
On / Off
Close windows and sunroof by turning and holding key in door lock
On / Off
Open windows and sunroof via long-press on remote
On / Off
Close passenger's window using single button press
Yes / No
Rear-left window single-touch-close
Yes / No
Rear-right window single-touch-close
Yes / No
Passenger window single-touch-close from driver's switch
Yes / No
Rear-left window single-touch-close from driver's switch
Yes / No
Rear-right window single-touch-close from driver's switch
Yes / No
Open/close power rear hatch via interior switch
Disabled / Close only / Enabled
Auto fold side-view mirrors (req. power folding mirrors)
With ignition / With door locks / Disabled
Lower passenger-side mirror when in reverse gear
Default / User-specified
Instruments / Display / Dings
Engine start indicator
On / Off
Display odometer after ignition is turned off for?
30 seconds / 1 minute / 10 minutes / Off
Ding when headlights are left on
Yes / No
Seat belt warning ding (driver)
Enabled / Disabled
Seat belt warning ding (front passenger)
Enabled / Disabled
Turn signal click volume
Low / Medium / High
Remote low battery warning
On / Off
ECO Drive indicator zone
On / Off
Lights
Coming-home lights duration
Off / 30 seconds / 60 seconds / 90 seconds
Auto headlights activation threshold
Darkest / Darker / Normal / Lighter / Lightest
Turn on marker lights when vehicle is unlocked via remote
On / Off
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after?
7 seconds / 15 seconds / 30 seconds
Turn on interior lights when you shut off engine
Yes / No
Turn on interior lights when you unlock doors
Yes / No
Turn on interior lights when smart key in range
Yes / No
Turn on exterior footlight when smart key in range
Yes / No
Interior footlight (bright when doors open, dim when driving)
Yes / No
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
Yes / No
Turn on exterior footlight when doors unlocked via remote
Yes / No
Turn on exterior footlight for?
Off / 7 seconds / 15 seconds / 30 seconds
Interior light control
Enabled / Disabled
Exterior light control
Enabled / Disabled
Heater & A/C
Ambient temperature calibration
-3?C / -2?C / -1?C / Normal / +1?C / +2?C / +3?C
A/C power
Automatic / Full power
A/C ECO mode
Enabled / Disabled
Open air flow to footwell when AUTO button pressed
Yes / No
Auto-increase blower speed when front defroster is on
Yes / No
Auto-turn on A/C when AUTO button pressed (if needed)
Yes / No
Also blow to feet in "face" mode
Yes / No
Seat heater mode
Automatic / Manual
Fan speed reaches its target?
Slowly / Normally / Fast
Other
Seat memory is enabled when unlocked from
Driver's door / Any door
Roll down rear shade when in reverse gear
Yes / No
Delay for rolling down rear shade when in reverse gear
Immediate / 0.7 seconds / 0.9 seconds / 1.2 seconds
Slide driver's seat back for easy exit
Off / Short / Standard
Move driver's seat side support for easy exit
Yes / No
Move driver's seat lumbar support for easy exit
Yes / No
Move driver's seat pelvis support for easy exit
Yes / No
Stop monitoring for car key signal after?
0 - 5 days
Voorbeelden van de Carista site:
Zouden zaken als op slot tijdens het rijden en automatisch inklappen van spiegels ook te configureren zijn op mijn 3GS?
Op slot tijdens rijden kan je configureren (zijn een aantal opties voor), maar niet met Carista. Dit kan wel met Techstream. Als we elkaar weer zien kan ik hiervoor wel mijn laptop meenemen
De dealer kan dit uiteraard ook voor je doen.
Oh, dat zou ik wel super handig vinden!
Ik rijd tegenwoordig vaak met mn laptop op de achterbank en ik moet er steeds aan denken om manueel de deuren te locken.
Dan heb je wel een onhandige instelling (of ik begrijp het niet). Bij mij staat het zo ingesteld dat vanaf 25 km/h de deuren op slot gaan en weer van slot gaan als ik hem in Park zet.
Dat wil ik ook
Misschien is dit weer zo iets als jouw soft close ramen die ik niet heb...
Nee hoor, een IS uit 2006 heeft dit ook.
Ik heb een GS450h 2006pre facelift en RoelVB heeft een facelift model waar de soft close ramen wel op zitten.
Waar ik naar verwees was een inside joke over missing features tussen modellen.
Wel bijzonder dat de 2006 IS wel soft close ramen heeft. Misschien is mijn GS gewoon niet helemaal goed ingesteld![]()
Nee, die soft close ramen heb ik niet, maar wel dat de deuren op slot gaan als je wegrijdt en pas weer open gaan als je de automaat in de P-stand zet.
Ik ben inderdaad ook op zoek naar de app waarmee ik de deuren auto kan vergrendelen met wegrijden. Volgens de dealert is dit niet mogelijk, maar in mijn beleving is het gewoon een software aanpassing met simpele verwijzingen naar bijvoorbeeld : als stand gearbox = D, dan lock Doors. Maar ik kan hef uiteraard mis hebben. ????
Zoals hierboven besproken kan dit bij de GS gen3, dus zou erg vreemd zijn als dat bij de gen4 niet meer kan.
Ja, die Carista app heb ik in de unlimited versie kan alles uitlezen en wijzigen in mijn CT200h.
Ben of kom je in de buurt van Hoorn dan kunnen we wat regelen
Vr.Gr. Twan
